Connection going down
fatshady
Is anyone else being booted of their plus net connection every few minutes during weekdays and the evenings.
I had my connection upgraded to 2mb, but what was the point - i now can't connect half the time. It seems everytime my connection is not running for a few seconds I get chucked off.
What use is that when I am trying to host a webserver?
Anyone else found the same? Btw - I'm on the 2mb premier service (£21.99 a month!)
Phantom_Flan_Fl
If it's only started happening since your upgrade, it could well be because your line isn't capable of supporting 2meg, even though BT said it did.
I had the same problems after my upgrade and had to get moved back down to 1 meg.
All you can do is raise a ticket............and be patient.
connection dropping out
I'm having same problems with my Plus net connection. Recently its started to throw me off every 5 minutes or so. If I wait long enough it comes back on but often quicker rebooting modem/router.
I'm using a Belkin modem/router and have updated firmware but having same problems.
Any ideas?
Jag7t
fatshady
Router Issues
It appears I was having router issues (although it could be too soon to speak)...
I changed my router two nights ago from a Solwise SAR-110 (the router plusnet supplied when I signed up) to a Netgear DG834G, and as yet I have not had it drop the connection.
However I've not used it that much in the evenings yet, which is when the problems happened.
The same thing is happening to me! I swapped my line filters as suggested by NetPlus Help and this has improved matters but not solved them. Anyone got any bright ideas?
I think i might have the same problem, every now and then my internet will just kick me and will try to get a sync for about 5 mins and then will work for a while and does the same thing
there are many things which will cause disconnects. Dodgy or insuficient filters. Poor internal wiring. Electrical (RF) interference and line quality, to name a few.
If your modem / router provides line stats then this would give an indication as to line quality.
Some of the tutorials from the usertools site would be worth reading, especially the troubleshooting guide.
Similar disconnection problems for me too - for some time now. Many of the posts here and elsewhere refer to diagnostics using modem line stats. Does anyone know if the Voyager 105 as supplied by Plusnet provides such stats? I suspect not.
Connection Interruption
It happened 1 yesterday; 3 times this morning. NEVER before this since I upgraded to broadband in November 2004.
I have just disconnected my phone line from the router for 30 mins. Re-connected and logged on. I am very curious to find out why!
Same...
Also had issues. Major problems on 07/07/2005, but not really since then except for once today. My line just drops and loses sync for a minute or two. Annoying...
I posted a message a few weeks ago, about disconnecting problem. Since then, I never had that problem until now. In the last 3 days, its back. I got disconnected at least 4 times a day.
I had broanband with AOL and Freedom2surf in the same house, same line, same router and It works fine. Get disconnected probably once a month.
Now the question is
PLUS NET, ARE YOU HIDING SOMETHING?
DO YOU NEED TO SPEND SOME MONEY TO UPGRADE YOUR SYSTEM?
Now the question is
Are you losin sync or being dissconnected just from PN?
Plus net have pages full of stats about how busy the network is toruble is i can't remember where!
Alecto
Start at this page for details of problems, links to system use stats etc.
what I notice is,
Sometimes the router will show its connected, but I can surf the net, I would need to wait for a 1 or so min before I can surf again.
/or I get disconnected so I need to connect again. Would take a few try.
I believe the problem lies with Plus net, because I was fine with AOL and Freedom2surf. (using the same line and hardware). Also, A week ago everything was fine, never had any disconnection problem. I though Plus Net fix the problem.
I will try to use a modem instead of the router, just in case its my router.
No they are not. if there were a general network problem thousands of people would be affected. Your recurring problem is most likely local or Exchange / line related.
Follow the advice given previously and read the tutorials and faq's for an understanding of possible problems.
