Connection dropped 06/05/02 at 02:45 ish???
Anyone else disconnected at this time?
(I know at least one other user was 'cos I saw his post on ADSLguide.org.uk :-)))
But my smoothwall doesn't appear to have re-connected, even though I've set "persistent connection" to "on"? I'm at work at the moment so can't investigate further - I just know that I can't access my home machines!
Anyone else with Smoothwall (0.9.9 p12) that re-connects?
Chris.
RE: Connection dropped 06/05/02 at 02:45 ish???
On examing my smoothwall logs it looks like it might be a USB or maybe a pppoa problem...
May 6 02:43:07 shmoowall pppd[6624]: No response to 3 echo-requests
May 6 02:43:07 shmoowall pppd[6624]: Serial link appears to be disconnected.
May 6 02:43:07 shmoowall snort: pcap_loop: read: Network is down
May 6 02:43:07 shmoowall snort: Snort received signal 3, exiting
May 6 02:43:07 shmoowall smoothwall: PPP has gone down on ppp0
May 6 02:43:08 shmoowall ipsec_setup: Stopping FreeS/WAN IPsec...
May 6 02:43:13 shmoowall pppd[6624]: Connection terminated.
May 6 02:43:13 shmoowall pppd[6624]: Connect time 4533.7 minutes.
May 6 02:43:13 shmoowall pppd[6624]: Sent 109793319 bytes, received 24117941 bytes.
May 6 02:43:13 shmoowall pppd[6624]: Using interface ppp0
May 6 02:43:13 shmoowall pppd[6624]: Connect: ppp0 <--> /dev/ttyp4
May 6 02:43:13 shmoowall pppoa3[14080]: PPPoA3 version 20011007 started by nobody (uid 99)
May 6 02:43:13 shmoowall pppoa3[14080]: Control thread ready
May 6 02:43:13 shmoowall pppoa3[14080]: pusb_claim_interface 1 failed
May 6 02:43:13 shmoowall pppd[6624]: write: warning: Input/output error (5)
May 6 02:43:13 shmoowall pppd[6624]: Modem hangup
> Chris.
Nope except for reboots while dual booting, I've been connected for the last 3 days and no lost connections that I noticed.
ADSL @ 288/576 Self Install
IRC.UTCHAT.COM
@ in #utgames #utchat #uthelp
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Yep the same here, the times are an hour out. It was about 02:35 when mine dropped.
01:34:58 pppd No response to 3 echo-requests
01:34:58 pppd Serial link appears to be disconnected.
01:35:04 pppd Connection terminated.
01:35:04 pppd Connect time 3715.4 minutes.
01:35:04 pppd Sent -44608451 bytes, received -1325362009 bytes.
01:35:04 pppd Using interface ppp0
01:35:04 pppd Connect: ppp0 <--> /dev/ttyp1
01:35:04 pppd write: warning: Input/output error (5)
01:35:04 pppd Modem hangup
But it had been up for ages before this.
Now all ok after a reboot.
Angus
