Connection Speed
Connection Speed
Why when doing a connection speed is it coming back with 0.000 kbps. It is showing me less than dial up.
Colin
Moderators note by John (johnessex) title corrected for you.
Connection Speed
Well I can assure you it's not 0.00 k else we wouldn't see the above!
Have you tried other speed testers what does the BT one say?
Connection Speed
Hi Colin.
Was that result from the Plus Net speed test?
Try the ADSL Guide Speed Test or as Daniel says, the BT Speed Tester
AG test is pretty reliable and the BT one, whilst requiring a little bit of configuration will give a very accurate result.
Hope that helps.
Connection Speed
Are you using a router?
Ever since I installed my Netgear DG834GT router I get all sorts of weird and wonderful speed test results. Sometimes 0.0000 which obviously isn't correct but astonishingly enough sometimes it tells me 218mbps. Yes I typed it right 100+ times 2mb!!!!!!!!!!!
Is this a current speed test issue with PN?
Personally I think it something to do with the router but I'm no expert.
Thx
Connection Speed
Yes I'm using a wireless router. And it defiently says 0.00 along with the chart showing that this is less than dial up. I'm using the PlusNet Broadband Speed Test. I also get silly speed returns much like the previous post.
Colin
Connection Speed
Hi Colin,
If you run the tests mentioned previously you should see accurate figures.
