Connection Speed
snapper_mart
Connection Speed
My connection seems MUCH better tonight? It seemed to be very sluggish over the past 4 or 5 days. Has something changed, or is fortune smiling my way for a change?
RE: Connection Speed
I was blazing last night aswell...although when i checked my uploads on ADSL guides speed test they only came back at 170, my download was good at 468.
Not really that bothered to be honest...i download a hell of alot more that i upload!
Its all good..........
I am getting downloads ranging from 460 to 190 kbits per sec, which seems like quite a large range !
Yeah that is a bit odd. It may depend on how many people are using the same exchange as you for their dsl connection. Remember it is set on a ratio of 50:1
