Connection Problems?
Is anyone else having problems with their ADSL connection? Mine just dropped, tried restarting the router but nothing. Using AOL dialup at the moment Sad
I'll raise a ticket I suppose - just checking if it's just me?
i got same prob getting disconnected and sometimes getting username pw not valid on domain..
Yup having same problems i just changed the dns numbers and im back on
could not connect for at least an hour
yeah i'm on 0845 dialup atm. not perfect but it's better than nothing. just hoping adsl is working again soon. 0845 isn't exactly cheap...
Plusnet Staff
Plusnet Staff
We had a problem with both the ADSL and 0845 platforms.
For more information check out the service status page at
http://portal.plus.net/supportpages.html?a=2
With any luck these problems should now resolved.
Yup - now surfing on the old dsl line. Thanks Smiley
i will be once i take the router out of the fridge. i really need a cooler place to put it :?
