Connection - Or lack of it!
Ok, I'll join the moaning masses.
My line was activated 5 days ago and I still can't connect.
My last ticket hasn't been replied to in 8hrs (and still counting!)
Is anyone using a US Robotics 8500 USB ASDL modem and Windows ME?
Can anyone email me comprehensive details of all the connection settings.
When I connect I get error 691 and a "password" failure.
If you can help please email me - weststander@hotmail.com
Looks like after this weekend I'll be getting my money back...
Thanks in advance.
RE: Connection - Or lack of it!
Hi
I have a D-LINK DSL-200 digital modem, but the set-up is much the same.
There is a help setup ADSL page if uou click on the customer support section.
When you enter you're user and pass on the 'fake' dialup box remember its "yourname@plus.net" a bit different from dialup user name.
the settings are 0 and 38.
Set the fake dialup number as 0,38 should work.
If not check the help section.
ADSL is messed up at moment, even i get error couldn't connect to network, takes me about 3 or 4 attempts, while other times i logon straight away, but the Upstream is terrible right now, i'm only getting 2-6 Kbs max.... downstream is alot better, but still very slow for an ADSL connection.
Jason
Thanks for your advice Jason,
Unfortunately my settings are as you said.
The "strange thing is I can connect to the bt_test@startup_domain connection but not my david1969@plus.net connection...sigh...
I have now had my problem "referred to BT" - it seems from reading these forums that the "It's not our fault it's BT's" seems a common "excuse"
Anybody else have any help...I'm getting desperate...:confused:
David1969
> Hi
> Jason
> David1969
> > Hi
> > Jason
Hi.
Consider yourself lucky David... I can't connect to anything.
Asim.
