Connection Dropping: Question + Work-Around
I have, since signing up about 1.5 months ago, been having a problem where my connection dies completely. This seems to happen either after 5-6 days of connection or after 24 to 36 hours [never, so far, anywhere in between]. This is quite inconvinient when I want to access my little server but am away from the house [so can't reset the equipment].
Is anyone else experiencing this? Could it be the exchange, or indeed my router? PlusNet's response [via the support-line on the first couple of occurances] is that they believe it to be an exchange issue, with the usual 'reset your equipment and disconect for a while' solution. FYI: I am using the router provided by PlusNet as part of the starter-kit.
The first couple of times I went through the whole 'disconnect and power cycle for 15 mins, try BT test...] procedure, but have since discovered that simply resetting the router via its web interface usually surfices.
Because of this I have setup a script [run hourly via Cron] that checks the connection and resets the router if it can't see certain sites [several know-to-be-reliable sites are checked, and a reset is only done if none of them are visible]. If anyone out there would find the script useful, let me know and I'll post it here.
1 REPLY
chino
RE: Connection Dropping: Question + Work-Around
I had a problem of i kept on loosing sync, and what i found ti to be was the telephone cable (not the one from the modem/router). I had a phone cable hardwired in the house (1 master and one spare). If i used the spare one i would get sync for 5 min then loose it some time a day or longer then it would die and could take hours to come back. I found out that if i run another cable from the master socket (cable from argos) then i do not loose sync and it all works fine...
cUnDaLl
1.7 GHz AMD XP, 768MB DDR PC2100 Crucial, 120 GB HD IBM Deskstar
Why do we do it because we can...... Smiley
