Connecting
Connecting
Is there a way of automatically making a connection via my Voyager modem each time I boot up - currently, I have to select 'connect' and wait each time while it 'connects' and 'verifies user name and password'
1 REPLY
Connecting
If you have a short cut to click on in order to connect you can put that in the startup group.
You could also put it in the registry
If you have IE set to connect automatically you can put IE in the startup.
