Connecting second pc to my switch
Hi there, im in a bit of a pickle!
ADSL is in, working fine and all that, but im having trouble setting up my flatmates computer to our connection.
He has XP, so i thought it would be fairly straight forward, but im kinda stuck.
Basicly our setup is: adsl modem/router > 8 port switch > PC's
Now ive set this up before in the old flat, but this is a different PC that has been in a different network for a while. I have set his internet options to connect through the network to the internet (using the wizzard :S ) and its not working. It error's as if hes simply not in the network.
Any tips/ things to do to descover the problem?
Is the switch running DHCP? If so, have you set up the new XP machine to use DHCP (Control Panel->Network settings->Local area connection->TCP/IP->Obtain an address automatically and reboot windows or restart the network adapter)? It might have been using a static IP address before which isn't in the range that the switch expects.
yea, it was nearly that Smiley
It had a dns server specified.
Put the plusnet ones in instead
