Connecting at 10mbps???
When I first installed my modem and connected it was at 10mbps.
After that its always 576.0kbps(normal).
Last night it connected at 1.0mbps so what is going on?
1 REPLY
RE: Connecting at 10mbps???
Hi Kevin,
Occasionally ADSL modems can be a little "creative" on the connection speeds they report.
This is normally nothing to worry about, unless it actually causes you a problem with your connection.
Please raise a ticket using Contact Us if this is the case.
Regards,
Richard
| Richard Allen................Unmetered & ADSL solutions
| Technical Support.....................for Home & Business
| PlusNet Technologies Ltd.........@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
