Connecting Via IE or OE6
Have just connected via ADSL. However I do not leave my PC turned on all day or all night so I disconnect the ADSL when I turn of the PC.
I am used to connecting to the internet by starting either internet Explorer or Outlook Express (v6), however when I do this it tries to connect via my old Dial Up Modem. Is there a way of getting IE and OE to connect via my ADSL modem by default?
Thanks in advance
Mike
1 REPLY
RE: Connecting Via IE or OE6
> Thanks in advance
> Mike
IE - Tools -> Internet Options -> Connections -> Never Dial A Connection.
Outlook -> Tools -> Accounts -> (Select Acount) -> Properties -> Connection -> Connect Using My LAN.
Should sort it.
Bill
