Confused! max dsl
namtab
Confused! max dsl
Hi, im totally confused, have been on max for 5 days now still no change on p-net speed test, same as it was on 2mb,(1.72mbps) is this the best speed i can hope for?,
I have posted some stats from my modem but need help understanding them please, also are they normal for a 8mb connection :?
Upstream
448 (Kbps.)
Downstream
2816 (Kbps.)
Noise Margin
24 dB
2 dB
Attenuation
43 dB
34 dB
Interleaved Path FEC Correction
816
50411356
Fast Path CRC Error
0
0
Interleaved Path CRC Error
11
4413
shellsong
Confused! max dsl
Is the 2dB SNR figure associated with the upstream or downstream figures? It is too low for stability unless the router is lying!
namtab
Confused! max dsl
The 2dB SNR figure is the downstream,im using a US Robotics 9110 router, it seems stable no disconects just slow for a 8mb connection
Confused! max dsl
I was up to 3.3 mbps when regraded but it has got slower eversince. Today it is 561kbps. Doh!
namtab
Confused! max dsl
mines the same just getting slower by the day, soon ill be better off on dia up lol. Evil
shellsong
Confused! max dsl
If it's stable maybe the router is lying about the SNR and the true figure is higher!
