Confused!!! Help!
Confused!!! Help!
Anybody else gettin really strange results from ADSLGuide speed testHuh Or is it just meHuh
Downstream 262 Kbps (32.8 KB/sec) 301 Kbps (inc. overheads)
Upstream 422 Kbps (52.8 KB/sec) 485 Kbps (inc. overheads)
Seems to be in reverse doesn't it...this isn't a one-off tho...it's regular. My download speed isn't impressive tho (even at this slightly non-peak time)...and PlusNet Big Brother confirms it.
Advice anyone?
RE: Confused!!! Help!
> Advice anyone?
Just tested on ADSLGuide with these results:-
Downstream 425 Kbps (53.1 KB/sec) 488 Kbps (inc. overheads)
Upstream 215 Kbps (26.9 KB/sec) 247 Kbps (inc. overheads
David
Downstream 273 Kbps (34.1 KB/sec) 313 Kbps (inc. overheads)
Upstream 423 Kbps (52.9 KB/sec) 486 Kbps (inc. overheads)
And again!! Bizarre!!! Really help!!
Downstream 264 Kbps (33.0 KB/sec) 303 Kbps (inc. overheads)
Upstream 231 Kbps (28.9 KB/sec) 265 Kbps (inc. overheads)
This was my test results...anyone have any ideas how to improve it?Huh
> This was my test results...anyone have any ideas how to improve it??
Changed my MTU to 1458 was 1400 and I got these results
Downstream 468 Kbps (58.5 KB/sec) 538 Kbps (inc. overheads)
Upstream 240 Kbps (30.0 KB/sec) 276 Kbps (inc. overheads)
On Dr tcp, what should the other settings be set atHuh or do you leave them as default?
Jim
thats as good as it gets
Jim
Here is my settings,
Tcp receive window... 13140
Window scaling ...... Yes
Time Stamping........ No
Selective Acks....... Default
Path MTU Discovery... No
Black hole detection. No
Max Duplicate Acks... 3
TTL.................. 64
MTU.................. 1430
And the latest speed results from adslguide are
Downstream 476 Kbps (59.5 KB/sec) 547 Kbps (inc. overheads)
Upstream 244 Kbps (30.5 KB/sec) 280 Kbps (inc. overheads)
Done all of these settings and the only thing i have that is changed for me since the upgrade, is my upload is now faster than my download still to get a download on any test screen of above 300.
Well i just tried your settings and got...
Downstream 290 Kbps (36.3 KB/sec) 333 Kbps (inc. overheads)
Upstream 425 Kbps (53.1 KB/sec) 488 Kbps (inc. overheads)
Still not great...and still getting the wierd upload speed!!
Jim
You have to shut down your comp completely for the settings to take, not just a restart. also check out this link
http://www.dslreports.com/faq/tweaks?text=1
I got to agree with something not being right. I have been doing some downloading and uploading and using du meter to see what is happening, what I have been seeing is downloads hitting between 10 to 20 KB/sec, while my uploads have been been hitting between 30 to 50 KB/sec, sometimes they do go higher or lower but most of the time they have been sitting in this range, I even seen upload speeds hitting in eccess of 60 KB/sec. I just wish my download speeds were the same as my uploads as i want the download speed more than the upload speed but it is weird it sounds like some1 has got the wires the wrong way around.
It is wierd...very...I have posted a ticket to Support...just waiting for an answer now.
Ho Hum.
