Conexant USB ADSL Modem & Suse 9.1 Pro
Hey,
XP has finally thrown it's last tantrum, and is getting it's books. What drivers/dialup apps do I need to use my Conexant USB ADSL Modem with Suse 9.1 Pro? What should I download and save on disk before the big format?
Anyone who with Linux experience, I would greatly appreciate any support, cos I'm just about to jump in the deep end and take my chances rather than deal with XP's nonsense anymore!!
Thanks,
AJ
Plusnet Staff
Plusnet Staff
I'm afraid I don't know whether your Conexant modem will work with Linux. Have you had a look at the Linux forum on ADSLGuide? You might find someone there that's already done it.
From experience most Linux/BSD users have routers as setting up a network card is generally a lot easier than finding drivers for a USB device.
Bin what you have got and buy an external modem/router. You will never have compatibility problems or driver issues again. All you need is a Network card and your done as most metwork cards are supported out of the box with Linux or come with the necessary Linux drivers. For £25 you can get an ebuyer origo ASR8000 which will work fine, or spend a bit more for a netgear DG834 which is a 4 port adsl modem/router with firewall.
Linux has limited USB and PCI card driver support so keeping things separate is the best way to go.
Thanks..
Thanks guys,
That sounds the business.. . Any recommendations? Easy of installation is my main concern, cos getting stuck into a new OS, I'll be wanting back online asap.. Cheesy
What do you have/use?
Thanks again,
AJ
I've already quoted 2 good routers, the orig ASR8000 is a single port router (the origo ASR8400 is the 4 port version) or the Netgeat DG834 4 port device. Both are easy to setup and recommended by many here.
Thanks again..
I'm going with the Netgear.. just cos it's cooler looking lol
Thanks,
AJ
also moving to suse 9.1 pro ...
Likewise my friend - down with xp.
Got SUSE 9.1 pro last week and been burning the midnight oil for a while...
1) suse/yast/parted screwed by mbr so xp wont load ( wanted to keep for a while) followed all suggested fixes to no avail - oustanding call to suse support !! Will have to partition disks xp/partition magic/manually on other pc's yuck.
2) I have belkin54g adsl wireless router ( was bout 60 quid from scan.co.uk which i pass on way home anyway ), use dhcp, 128bit wep encryption and mac address security. At first I connected by 10/100 cable and then got wirless working, I am by know means an expert and took me about 1 day in all - took my mind off football on Friday when I was at home with flu. I had to edit the eth1 config file to add wirless params etc - 10/100 worked straight away with eth0
PS I only changed to router 3 weeks ago but its much better.
3) email,browsing,amsn all worked straight away with kde once network set up .
4) Had to download nvidia driver to get 3d screen res but no problem there.
5) Can't get dvd player to install yet ...
First impressions - I am very impressed with SUSE 9.1 not seen linux since suse 6 which was lacking ... still reserving judgement versus xp while I learn ..
PS. I have toshiba sat pro m10 latop which is centrino so wirless lan very handy
I haven't touched other 2 xp machines yet still playing with tosh ...
