Conexant PCI Modem
Conexant PCI Modem
I have had to revert back to Win Me for my modem to work, have tried the following drivers
2.085.010
2.099.002
2.099.021 works with Me
2.099.040 from plusnet
2.099.040 from the-madhouse
2.099.040 (PT 3805) from mri
2.099.040 from avgs-tech.co.uk
2.099.040 from amigo.com/tw
None of which work with Win XP home
Has anybody got an ideas on how to get modem working with XP
I have changed vci to 38.
The nearest I have got is 2.099.021 which works until restart the computer then does not, however uninstall and re install it then works and after restart does not.
chino
RE: Conexant PCI Modem
Yes i will be one sec, i am making an iso now and i will post a link for you in a mo....
cUnDaLl
chino
The drivers for XP
http://www.cundall.plus.com/Conexant/
This works for XP Pro with all updates installed
cUnDaLl
Hope this helps...
