Conexant AMX64 router firmware(?) issues
with the said router, using the latest firmware (with port forwarding), i cant seem to access some websites i.e. www.xbox.com, in the process wont let me access XBL...it used to work though, been weird the past several months
however, if i use an "older" firmware (limited port forwarding), all sites are fine but i do need more open ports
anybody experienced the same problem? or anybody has a newer firmware that allows a wider range of port range mapping?
btw, im using this version: CA6XR-GN.0924.00T
thanks a lot
Try this link for settings and a link to the latest firmware.
http://www.cazart.plus.com/conexant/
Jeff
Does your router have a DMZ setting? you could always put your Xbox in the DMZ - Problem Solved!
It's what I do for my PS2.
jeff, tnx for the link but that's where i got my firmware as well, still wont work
gadgetboy: can't do a DMZ, defeats the purpose of the firewall in the router, i just need a few more open ports, tnx for the heads-up anyway
i dont like to rule the hardware as a whole as defective, since everything works well with an "older" firmware. its just that the port forwarding range is limited to 20...and besides it "used to" work well with the latest firmware
any others?
cheers!
Be thankfull, my router is good (netgear) but only has 10 port forward entries.
However the DMZ on mine, only disables firewall protection for the IP address I select not the others. Xbox's and PS2's don't need firewall protection, they are not open to be hacked in the same way as PC's.
Could you not just open a greater range of ports to the IP address of your Xbox?
kimera
you can try these links below:
How to set up DABS Conexant AMX-CA64E Router in the UK
http--forums.whirlpool.net.au-forum-replies.cfmt=86201
Quote:
http://forums.whirlpool.net.au/forum-replies.cfm?t=86201#r13
http--www.thecaretaker.org.uk-routers-amx-amx.htm
Quote:
http://www.thecaretaker.org.uk/routers/amx/amx.htm#files
Origo Support Forums
Quote:
http://adsltech.7host.com/forum/
Pete Ashton's Weblog The informal eTEC PT-3812 ADSL Router help desk
Quote:
http://www.peteashton.com/001128.html
Whirlpool Forums - Thread WebExcel PT-3812 LAN and server setup
Quote:
http://forums.whirlpool.net.au/forum-replies.cfm?t=127593
as you have see above some i have put another router etec pt-3812 as this is bcoz they use the same chipset suppy by the same company.
if you decide to flash the firmware..think twice..must sure write down the firmware version can be check on your router address.under status->homeand check has the web still got ur version..
i prob guess either the settings or firmware prob.
P.S check the firmware<-----
i try upload the CA6XR-GN.0924.00T ,most of the site i cannot get throught...if you still cannot go to any site..better use the orignal fireware (the one b4 u update)
as i cannot log in to ebay.co.uk or tiscali.co.uk when i use the latest firmware.
i think i posted some info on ere: i know is diff make router,but use the same chipset..
GIVE ME SUPPRISES WHEN YOU FIX THE FIRMWARE,also SUCX not much support from conexant
