Conecting -- New Customer
stathe
When I start up my computer and the modem (voyager 105) eventualy fires up the box to conect to plusnet comes up, I have set it to auto conect, but it says not recognised username or password ,re-enter password and all is well. Why should this be?? I have all the correct entries
When were you activated and when were you due to be activated?
Also what do you have as the username?
stathe
Activated 8 August , I think but not working properly until after B.T visit 16th Aug
User name stathe@plusdsl.net
It may be that the stored details are incorrect. Is there anyway to tell it to 'forget' the stored username + password so you can re-enter them?
stathe
I keep doing that
stathe
Poor connection
Still haveing problems ,yesterday I thought all was well as I was able to stay connected for hours at a time, to-day it isonly for minutes,modem does not sync and when it does is unable to conect to plusnet . Now I understand I need topay to leave, even though satisfaction was guaranteed.Try to send this, power and DSL lit on the modem, but unable to establish a connection,it will eventualy ,but is far from satisfactory .
