Computer crashing and DSL disconnecting.....
Hello there,
I just installed my DSL and my computer keeps crashing after I've connected. And the connection seems to cut off a lot as well. I'm using XP Pro and the modem they sent me is an EA900 - the software says V5.3.2 Annax A
any ideas?
Re: Computer crashing and DSL disconnecting.....
[Not an XP user]
If its a USB modem u might have to get a powered hub.
See http://portal.plus.net/central/forums/viewtopic.php?t=10841
Do a search for usb+hub.
HTH
Moderators note (John) Quote removed. There is no need at all to quote the entire contents of the immediately preceeding post. Quotes should only be used for emphasis of a particular point from a post or to refer to a post further back in the thread.
okay, thanks a lot I'll give that a try. Is it because my PSU isn't powerful enough?
