Compensation
Compensation
hi i think its about time plus-net gave their customer,s something back for all the down time, there is always a problem but there are quick enough to take your money off you each month, I also asked to be upgraded to 8mb speed that was weeks ago and still nothing, and they keep asking you to switch your home phone to plusnet as it is cheaper i think they should get the other problems sorted out first. Yes as you can gather i am totally p***** of with there services so started to look at another provider wish i had never joined plus-net
