Come on Plusnet, its now 10.30am. Get it sorted!
kiasu
An update would be appreciated guys.
Some sort of ETA to avoid us sitting at our computers wasting time.
Is this too much to ask for?
Regards
espresso_mick
RE: Come on Plusnet, its now 10.30am. Get it sorted!
> Regards
You haven't read the latest service status message then?
You could change your preferred DNS to
213.120.62.100
...everything works fine with this.
kiasu
> > Regards
> 213.120.62.100
How do I change this Mick?
According to the service status report everything has been up and running for 50 minutes now. This is not the case with my connection.
Cheers
Mark
espresso_mick
The location will probably differ slightly depending on your operating system.
I have XP Pro and in the properties for my internet connection there is a Networking tab. After selecting this I can select properties for TCP/IP and change the DNS in there.
Changing the preferred DNS to 213.120.62.100 certainly fixes the problem, but where is this stated in Sewrvice Status ? Couldn't find any reference to this fix. Very grateful to you for your help 'though !
kiasu
I also have Windows XP but I cannot find where to change my DNS settings.
Would you please advise
Regards
Mark
