Cisco 857W
Cisco 857W
I have a problem, and I need some cisco help. I am having issues trying to get it connected to plus' network, the line protocal never seams to come up. I have included the current config below.
Current configuration : 3267 bytes
version 12.3
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname hsnetwork
boot-start-marker
boot-end-marker
logging buffered 51200 debugging
logging console critical
enable secret 5 $1$G0WV$TQpsD4lkA1Jns9ReLsU7A.
username dans privilege 15 secret 5 $1$9wHv$CnUQM6NFp0DLz29a6HE/d0
clock timezone PCTime 0
clock summer-time PCTime date Mar 30 2003 1:00 Oct 26 2003 2:00
no aaa new-model
ip subnet-zero
no ip source-route
ip dhcp excluded-address 10.10.10.1
ip dhcp pool sdm-pool1
import all
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
ip cef
ip tcp synwait-time 10
no ip bootp server
no ip domain lookup
ip domain name plus.com
ip ssh time-out 60
ip ssh authentication-retries 2
no ftp-server write-enable
bridge irb
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description $ES_WAN$$FW_OUTSIDE$
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet0
no ip address
no cdp enable
interface FastEthernet1
no ip address
no cdp enable
interface FastEthernet2
no ip address
no cdp enable
interface FastEthernet3
no ip address
no cdp enable
interface Dot11Radio0
no ip address
ssid SSID
authentication open
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root
no cdp enable
bridge-group 1
bridge-group 1 spanning-disabled
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$
no ip address
bridge-group 1
interface Dialer0
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname hsnetwork@plusdsl.net
ppp chap password 7
interface BVI1
description $ES_LAN$
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
logging trap debugging
access-list 1 remark INSIDE_IF=BVI1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.255
dialer-list 1 protocol ip permit
no cdp run
control-plane
bridge 1 protocol ieee
bridge 1 route ip
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
transport preferred all
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
transport output all
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
Cisco 857W
all ill say mate is "LOL" :p
firstly ZOMG YOU DONT NEED SUCH A HUGE CONFIG!!!!111!!!!
and oh, ill help you set it up -- like I said I would :p
once again to re-iterate == LOLERSKATEZ!!!!
Cisco 857W
Ok, and that in english was? As for the lengh of the config, that is the full config, i didnt think of striping out the ethernet stuff..
I think my problem is the dsl operation-mode auto, which is common, according to the cisco forums, Just havent had a chance today to change it, and see if i can get a steady CD.
Anyways, thanks for the helping. Smiley
Cisco 857W
hi hsnetwork.. did you get this working OK in the end? The Cisco is a seriously specialised piece of kit so I would suggest you try the ADSLGuide DSL Hardware board for help
Cisco 857W
ill help you -- seein as i have quite a few cisco certs under my belt, drop me a pm when your free to talk and ill try and walk you through it over msn or what not -- save lots of time between try this etc...
and the config is rather long for what you need, but no worries i am sure it will manage Smiley
Cisco 857W
Well, I still have no joy on this Sad have a ticket open with cisco now.
