Check on speed
Check on speed
I see my account was recently upgraded from 512kB to 1MB. How do I check if my connection is running at the new speed?
1 REPLY
Alecto
Check on speed
Your router/modem should tell you what speed your line is connected at. Look at the instructions that came with it, or do a Google on its model number for how to get this.
Or if you click Connection Settings on the left hand side of this page, you can run the Bandwidth Speed Test which, depending on time of day, should show something approaching your new speed.
Make sure nothing else is running at the same time.
