Changing username?
Changing username?
Is it possible to change the username you log in with?
csogilvie
Changing username?
Not AFAIK, as everything is tied to the username.
Changing username?
No, there are too many systems within PlusNet that reply on the username as a key identifier. When you signup, there are automated systems that create all the necessary database / file updates and there is no automated method to change all the systems. A manual method is also out of the question due to the complex nature of the internal systems PlusNet use.
