Changing to BT - will it improve line speed
jennies
I have apparently been upgraded to 8mb (ages ago), before the upgrade I got speeds of about 1Mb and since the upgrade it's never been above 500kb, sometimes lower than that. Had a ticket doing the rounds, but apparently it's BTs fault, if I change to BT will I get better speeds or could it really be the line?
1 REPLY
Fixes: 8
Can you post the results from http://www.speedtester.bt.com/ and the stats from your router/modem - http://www.kitz.co.uk/adsl/frogstats.htm may help you find these.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
