Changing static ip
Changing static ip
How do i change my static ip, so that i would eventually have a readable ip, which my friends can remember?
RE: Changing static ip
Don't think you can... it has to be allocated by PlusNet. Are you after the equivalent of a cherished number plate?? :-)
<username>.plus.com resolves to your static IP address, so your friends should be able to use that domain name instead of your IP address. That should be easy to remember, unless you've given yourself a strange username Smiley If whatever software they are using will only take an IP address, the can always ping <username>.plus.com for a reminder.......
