Changing MTU setting in WinXP Pro.
I'm posting this because I had trouble getting Dr.TCP to work with my version of Windows (after saving the settings the registry wasn't altered.
The following is a guide that tells you how to change your MTU setting in WinXP/2000 directly using the registy.
Open up regedit. You can do this by going to 'Run' in your Start Menu, and then typing 'regedit' in the box.
Navigate to HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Tcpip\Parameters
In the right hand pane right click and create a new DWORD Value.
Name the key MTU
Check the decimal radio button and enter your MTU Value. (145Cool
Exit regedit. Reboot.
Hope it helps.
1 REPLY
RE: Changing MTU setting in WinXP Pro.
Good post, I was able to change my value using DR TCP using Win XP.
There is another utility available called TCP Opimiser which will attempt MTU setting changes on a windows system.
Best Regards,
Dave.
| David Watson. Unmetered & ADSL solutions
| Technical Support. for Home & Business
| PlusNet Technologies Ltd. @ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet ----- +
