Change speed & included bandwidth
Any tried using the option "Change speed & included bandwidth" on this page http://portal.plus.net/products/broadband_home.html It doesn't seem to work - it just goes back to the product and services info page (http://portal.plus.net/info2/index.html).
thanks,
Michael
you have to use the contact us for that, detailing what exactly you want. Then CS will action it.
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Change my package
You may be right. You can use the "Contact Us" link to raise a ticket and get your usage change, but what is the point of the "Change my package" screen. It's a great idea to be able to upgrade and downgrade as you wish but an anoyance to have to raise a ticket each time.
csogilvie
I think it works if you are already on the new packages.
