Change password?
Change password?
:roll: simple question.. How do I change my BB login password?
holdtight
Change password?
Hi
You can change your password easily Here
Bill.
Change password?
Shockedops: LOL... well I think that it should have been easier to see.. I mean haveing the words "Change Password" in my account area is abit vague Shockedops: ... Cough.. Cough.. Thanks
Isitme
Change password?
I am still confused by what you can use for passwords. My password begins with numbers, which according to according to the Rules, cannot be done :? Is it because it dates back to 'dial-up' days, when this rule might not have been in force?
Plusnet Staff
Plusnet Staff
Change password?
Yeah, I think so, well the length of time ago rather than being dial-up. Some people have symbols in passwords as well from prior to whatever it was that changed (mail I think) that meant the password formats are as they are now.
Fixes: 57
Change password?
I am another one with a mix of numbers and letters with numbers first.
Can I ask why it was changed as it must reduce, if only a little bit, the password security.
