Certain websites not loading/or taking a long time
Recently within the last 2 days or so, certain pages seems to be random, take a long time to load up, or wont work at all, this seems random, and i still have my full bandwidth, i recently updated the firmware on my router but i fail to see how it would only effect certain sites, email irc msn gaming etc are all fine.
Check service status, they have just made a posting with regards to this type of problem.
Chris
The best thing to do is raise a ticket listing the websites you are having problems with, and if possible also perform traceroutes to the affected sites at the Windows command prompt - e.g.:
c:\tracert www.bbc.co.uk
Please then paste the results into the ticket you raise, then we'll investigate for you.
