Caps?!?!?
Caps?!?!?
Are there caps on service? I have seen some folk moaning about stealth caps, is this true? Or does it depend on what service you are on?
Cheers
JM
Caps?!?!?
top of the forum.... use the search button
Caps?!?!?
Cheers, but it's not much help.
There are loads of conversations regards it, and talk of a badboy pipe, but nothing solid anywhere.
Can anyone point me in the direction of some firm information on this, and can someone from Plus respond officially?
JM
Caps?!?!?
Ok this is unofficial as I don't work for PlusNet but I think its pretty accurate.
There are no Caps as such and you can download as much as you want from the net.
However what is expected of customers is a fair usage that doesnt cause problems to other users by hogging the resources of PlusNet.
What this in reality means is that if you continually download more than 140gig every month then you are affecting others.
It is accepted that there may be occassions where you need to download a lot and maybe exeed what is considered to be fair usage but as long as its not continuous then its not a problem.
Hope that goes some way to giving you some idea of the situation.
