Capped or what?
Capped or what?
I am on the PlusNet Broadband Premier - Up to 2Mb, paying £21.99 a month, and just been to view my usuage and it says I have used 0.91 of 1gb this week, I thought if you were on this package you were not capped?
Help me here please?
If you go to: http://www.leggott.plus.com/forum/plusnet/usuage.bmp you can see what I mean.
Alecto
Capped or what?
If you Tongue read the writing on the page you linked to, it tells you that the scale will adjust each time you use more and the 1Gb is not a limit, just the extent of the current display.. No you are not capped.
Capped or what?
Thanks for that.
