Cant view some websites?
My computer crashed on me loads yesturday. I fixed the problem it was the ram . I used hjack this tool and since then i cant view one or two websites. Any 1 no what it could be
You should know the drill by now from other threads:
- reboot PC and any external ADSL hardware
- disable any firewall or virus software (may need to uninstall to properly disable some)
- disable any pop-up stoppers
What sites can you not access and what do you mean by that: 1) DNS errors 2) page loads partially 3) no images 4) page loads slowly etc.
The chances are what you have done recently has cause the problem or the system crashes have corrupted some files. Try reinstalling/repairing your browser
For about a week one website has not worked. But one website i visit alot thinks about loading then just dont load. I have tried restart etc no go.
It says cant find server or dns. Damm computer
