Cant connect with Linksys WAG354G
Just moved house and got a WAG354G (Linksys Wireless Router), using my old Voyager 105 USB modem I can connect with no problems. Linksys does not want to know..
Settings : Encapsulation PPPoE
Multiplexing : LLC
Autodetct : Enable
Username : user@plusdsl.net
DSL status is up, Gateway is showing interface as down..
Any ideas?
Should be using PPoA not PPoE
Also VC-based with VPI 0 VCI 38, not LLC
That did the trick Smiley I tried PPPoA but didnt know to change the other setting to 38. Thanks!
Someone else who popped into pcworld recently then I see. Not a bad deal.
On checking my line stats my dowstream attn has gone to 44 from 39 with my snr going to 18 from 23.
A
You are so right. I went into PC world for a USB cable and saw this for sale and snapped it up. Replaces my old 'stingray' USB modem + vigor2200 + netgear wireless boxes quite nicely.
