Cannot connect to some websites
Can anyone help? I can connect to many websites, but some seem to have stopped working today. Things like www.if.com, www.scottishwidows.co.uk (yes, I'm doing money stuff today), but also www.kelkoo.co.uk
I've tried mozilla, IE and Opera and I've even turned off my firewall temporarily and no difference.
Any bright ideas anyone?
I go through an ADSL 4 port router, never been a problem before
Thanks!
You could have bad DNS records locally on your machine.
Go to command prompt and type
ipconfig /flushdns [enter]
and then try again.
Thanks but still no joy
Checked the router too, but all configuration seems ok Sad
Well, I can access all three sites with no problem.
Last suggestion is to turn off the router for 10 minutes so as to get a new VP and then try again.
What DNS servers are you using ??
Should be 212.159.13.49 and 212.159.13.50
The 13.49 and 13.50 DNS servers at PlusNet were under DOS attack yesterday but are now operational.
Bingo!!
You're a star - thanks! Cheesy
