Can you recommend a reliable router?
4 10/100 ports
Wireless g that is stable with WPA!
Good in/out firewall so i don't have to bother with a software one.
As much configuration as possible. Cheesy
Thanks for looking.
Simple... Netgear DG834G
Midville
Same as above no problems with it.
I must add you should flash it with the latest firmware 2.10.22 for a stable and reliable connection. Earlier firmware had a few 'teething problems'.
