Can the Solwise 130 tell me the attenuation and S/N ratio?
Dizzley
I may be being particularly thick this morning but can I see attenuation and S/N figures on my Solwise 130 router?
Just wondering.
/diz
I have a solwise 715+ router and can show various items including attenuation and S/N ratio by using Telnet. I simply open a dos window and then telnet to the ip address of the router. Then you can just use the various "show ADSL" commands to find the info you require. Not sure if this will work on a Solwise 130 router, could give Solwise a bell as they are very helpful. Hope this might help.
[Moderator's note (by Chris P.): Accidental double post removed]
Dizzley
Ah! I found it -
On the main page highlight "DSL".
Then click "DSL Params".
Done.
/diz
tests
What's an OAM test? I seem to have this option with my router. You can choose F5 end, F5 seg, F4 end, F5 seg.
