Can't remove bogus email
DerekB
There is a zero byte email - signed as 12June 00.00 - which causes an error message every time I do a Send and Receive - I've just set up webmail to look at it but can't delete it from there.
Apologies if this should be posted elsewhere.
Derek@thebriggs.plus.com
Have you tried the beta webmail to see if it can delete it.
If that fails, raise a contact us ticket and get support to delete it for you. It may be related to the movement of mail accounts to the new storage system.
DerekB
OK thanks
Derek
DerekB
Original webmail didn't get rid of it - but the new Beta version has - thanks again
Derek
