Can't connect
Can't connect
Anyone else having probs connecting to www.adslguide.org.uk ?
Cheers
community
Can't connect
Are you sure you got the url correct?
I don't recognise the .or bit !
Itried your url without success
cheers
Eddie Johnson
http://www.yamahakeyboards.info
Can't connect
its down with me too
must be serious
Can't connect
Can't connect
Soz missed the "g" Shockedops:
Conor hows the new place? You still mr fix-it, or break-it as the case may be?
Can't connect
had a major diaster at the weekend... stripped wallpaper in main bedroom but more than the paper came off!! stripped off hardwall as well! so have some one coming tomorrow to replaster.
Can't connect
Ah well at the least the missus is keeping you busy! Wink
