Can't change MTU
Bigbrotherjx
Can't change MTU
I've used the DrTCP program to tweak the connection, but when use the Tweak Test on DSL Reports, the settings seem to be the same. Whats the problem?
Can't change MTU
Are you rebotting between changes?
Bigbrotherjx
Can't change MTU
yes
Can't change MTU
do you have a router? If you do its the router MTU that needs to change
Bigbrotherjx
Can't change MTU
no router
Can't change MTU
In DrTCP, you need to edit the RAS MTU and if listed, your specific modems MTU for settings to take correctly.
Some modems can be listed, but require the RAS MTU changed specificly.
