Can't Disconnect
Can't Disconnect
Hi
this may seem not seem like a problem at all for most users. When i want to disconnect i have trouble, right clicking on the flashing tv icons and clicking disconnect mostly has no effect, the program stops responding. if i try to re-connect straight away tnothing happens and i need to restart the pc(pushing in and holding the off button usally-because xp hangs) Can someone help??
thanks
1mb premier
1 REPLY
Can't Disconnect
I have the same problems occasionally. It happens when it shows that i'm connected but there is no data transfer and cannot connect to any website, when I try to disconnect it just doesn't allow me and I have to force a reboot.
