Can't Connect... Again... Why?
Gibble
Hi
just got the upgrade to 8meg however when i download it sitll downloads at 2meg yet speed test shows the 8meg download speeds.
Right at the momment i can't connect this has happened a few times i woudl like to know whats going on, im having to post this on my friends connection.
When will i be able to log in again
Is it my modem which is my speedtouch (silver dome one can't remember model number).
I'd jsut like to get back on to the internet and carry on with my work.
Thanks in advance
During the 1st 10days of MaxDSL the system is testing your connection to find the best possible speed so that can cause numerous disconnections. Also a BT system known as BRAS rate limits your speed, for some reason there seems to be a fault on the BRAS which is not lifiting your speed up to the speed at which you connect at and its staying on 2mb.
Also note that with a USB modem you will never receive 8mb due to the nature of USB modems and the speed of USB, I would recommend upgrading to an eternet baed modem for MaxDSL.
Gibble
When you say ethernet do mean a router?
Yes he means an ADSL Router.
