Can someone explain?
I seem to be having the same disconnections as everyone else but don't believe I have been upgraded to MaxDSL. Plusnet have run some tests and the results have shown no fault was found. To me the loop loss looks very high and at the start of the results it indicates a main bearer fault.Does anyone know if the following results look normal:
xDSL Status Check Analysis
Likely metallic bearer fault but could be Line card or CPE.
Circuit Information
Circuit In Sync
Upstream xDSL Link Info
Loop Loss 41.5 dB
Cell Count 0
Downstream xDSL Link Info
Loop Loss 43 dB
Cell Count 0
Determine Algorithm Branch Analysis
Non EOI Line.
Copper Line Test Analysis
Test OK.
