Can someone explain my test results please?
katie
My internet connection has been getting progressively worse for 4-5 weeks until now, it is only available for a short while every 48 hours or so (until today). Plusnet have been very helpful and identified that my fault is on my BT line as my PC will not connect even from the master BT socket. I have tried a new modem, splitter, rj45 etc. & nothing works. Today, suddenly the internet connected again at about 9.15am, after 48 hours of disconnection, and is still on at the moment 13.25PM. When I checked my question with all these problems on the Plusnet Help & Support site, they said that they will refer my problem to BT. Plusnet sent me the results of some test they had done at some point and I wonder if anyone can explain it to me or whether they can spot a fault there which has prompted them to contact BT for me.
The results are:-
Analysis
OK.
Circuit Information
Circuit In Sync
NTE In Service
NTE Power On
Bypass Not Activated
MUX In Service
Upstream xDSL Link Info
Loop Loss 27 dB
Margin 22 dB
Errored Seconds 0
HEC Errors 0
Cell Count 255
Speed 448 k
Downstream xDSL Link Info
Loop Loss 51 dB
Margin 15 dB
Errored Seconds 0
HEC Errors 0
Cell Count 3080
Speed 3584 k
DSL MAX
Downstream Line Rate 1728
Downstream Line Rate Timestamp 26/09/2006 18:36:55
Maximum Stable Rate Re-set (Y/N) N
Profile Change Time 07/09/2006 11:17:25
Maximum Stable Rate 4000
Fault Threshold Rate 2800
Interleaved Auto
Richard Allen CSC Agent 12:18pm, Thursday 28th September 2006
Dear Mrs R,
I've now raised your fault to BT, please allow up to 72 hours for the next update.
Thanks for any help on this. Katie Smiley
katie
Lots of views, but no replies. Does that mean that everyone else is in the dark as much as I am?
Katie
Liam
This fault has been raised as a fault to BT by the looks of it.
These, really, are more for our reference and BT's to enable us to monitor your line stats. You don't really need to worry too much about them.
They give us your line speeds and error counts, as well as the noise on your line etc...
katie
OK Thank You.
Katie Smiley
