Can i turn off interleaving ?
ady
Hey, im on broadband premier option 1 and have just started to play first person shooters
And ofcourse I have joined the many people whining about their ping!
Would it be possible for me to have interleaving turned off, for a few days Smiley and if it doesnt improve can it be turned back on Tongue
Thanks -ady
Raise a ticket and this should be done within a few days.
ady
Will i be able to swap back if i get disconnections ? My SNR stays at 15, so I wouldn't think i will get any discs
You should have the option to do this in the portal under connection settings. Some people dont have the icon but most do.
took about 6 weeks for mine to be done by bt.
A
ady
Well, i cant seem to find an optoin in connection settings
Fixes: 57
It is probable that interleaving was applied automatically by the BTw system and hence the PlusNet system don't know that it has been applied.
This problem was found when the option was first introduced
ady
I had interleaving applied even though my SNR is averaging 15 SNR which sucks.
Guess I will raise a ticket
monty
until now it has taken over 3months for me to get interleaving removed, it is still on my account. So I would hold your breath for a quick removal.
montymole
do you still have you phone calls with bt or do you use a different carrier?
I have use tucan but used to be with bt. Could it be that bt take their time if you don't have calls over the bt network.
A
