Can anyone recommend an ADSL Router/Modem
Just signed up for ADSL and wondered if anyone can recommend and ADSL Router/Modem? Ideally I wanted a 10/100 4 switch version.
Is anyone using the AMX-CA64e from DabsHuh
Regards,
RE: Can anyone recommend an ADSL Router/Modem
> Regards,
> John
I am...
works very well and at £77 + vat its the cheapeast router to my knowledge on the market.
Kind regards
Kevin
| Kevin Revill ............... Unmetered & ADSL solutions
| Technical Support ................. for Home & Business
| PlusNet Technologies Ltd. ....... @ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
Can you use VPN and MSN Messenger with it okHuh
> I am...
> Kind regards
> Kevin
Sorry dont know I dont use messenger or VPN. Why not have a look at the review on ADSLguide.org they may have the answer there.
Kind regards
Kevin
> Regards,
> John
Not sure if you've taken a plunge on this one yet, If not, drop me a line at advice@perleman.com
Is this just a router or does it have a DSL modem built in as well? The DABS info seems sketchy to me, saying it had a USB port as well.
