Can anyone point me in the right direction?
I've finally found where my Router gives the information that enables a person to judge what speed capability they have on their line, however i don't know how to interpret it. Could some give me a link or somethin to a place where this information is available? It' used to be in the forums somewhere but i'm damned if i can find it now.
http://usertools.plus.net/tutorials/id/12 will help you.
Also post the stat's here...
Thanks for the rapid response Solstans. I've reviewed the data and think i'll be ok to receive 2mb when BT get round to upgrading my connection. However, i'll post my results here and let some of you peruse them to see if i've got it right.
Mode: G.DMT
Type: Fast
Line Coding: Trellis On
Status: No Defect
Downstream Upstream
SNR Margin (dB): 30.6 29.0
Attenuation (dB): 8.5 11.0
Output Power (dBm): 11.9 5.6
Attainable Rate (Kbps): 10880 1132
Rate (Kbps) 576 288
K 19 10
R 0 0
S 1 1
D 1 1
Super Frames 804542 804540
Super Frame Errors 1 0
RS Words 0 0
RS Correctable Errors 0 0
RS Uncorrectable Errors 0 N/A
HEC Errors 0 0
OCD Errors 0 0
LCD Errors 0 0
ES Errors 1 0
What do you think?
yep should be good for 2mb.
Excellent! Thankyou Solstans.
