Can anybody recommend a good ADSL router ?
Can anybody recommend a good ADSL router which has the following:
Ethernet connection
Built in modem
Router
Built in Swicth or hub (more than 2 ports)
Hardware firewall
.....maybe can connect with my PS2
.....Possible even wireless (but not essential to keep cost down)
I have been lookin at the Linksys WAG54G but little expensive 4 me at £100
Also was it the router modem like that plus net send u (I know it only has 1 port so no good 4 me)
I thought you already asked something similar in this thread.
If you want all you are asking for then you will need to pay a bit more than you are expecting. Proper firewalls don't come cheap neither does wireless and 4 ports and a modem.
The Netgear DG834G has everything you need including wireless or use the DG834 non-wireless version which is cheaper (£84 on ebuyer).
D-Link do a good range also, just check their web site - DSL-504 non-wireless and DSL-604+ wireless..
Basically you get what you pay for - pay less and you get less features which is sometimes a false economy. Maybe save up a bit longer and get a better product.
There are several other threads from members asking similar questions so look around for additional advice.
Cheers
Peter Cool
I personally have the D-link DSL 504, and would recommend it to anyone. Once you upgrade the firmware to the latest version, it runs beautifully (allows MSN file sharing, etc) and has a lot of good features.
Thanks Peter
Thanks you peter I think I will save up and go for the Netgear DG834G
Sounds easy to use and setup and does everything i want
Hi eurotrain4
Does the Netgear DG834G also support MSN file sharing then or not
sorry 4 asking novice questions
All routers should support file sharing - it's a bug if they don't!
Thomas
As Thomas said, every router should support it (though maybe with some minor settings changed) - my router crashed out every time I tried to do that sort of thing. But upgrading the firmware fixed it, and now I'm very happy with the router.
