Can PlusNet please check my BRAS setting
Fixes: 57
Last night we had a series of power cuts in quick succession during a thunderstorm before I turned off the router.
Each resynch was at above 3500 kbps but this morning speed tests are giving results under 500 kbps (ADSL Guide was 70 kbps, PlusNet 284 kbps bbmax 387 kbps). The stable rate is still showing as 3000 kbps - before I start fiddling can someone check my actual BRAS setting.
put a ticket in as i bet you've got a bad delta report back .. i had the same problem when a tree fell on my phoneline and PN said i had a funny delta report back which lowered my speeds
Fixes: 57
Ignore this request - just did some more tests
Did the BT speedtest - 2617 kbps (best result ever - never got over 2100 kbps with PlusNet)
Reconnected to PlusNet - now on ptn-ag2 - speed 1911 kbps
Results on thn-ag1 were very variable but all somewhere between 280 - 512 kbps)
From this it very obvious that thn-ag1 is choked and even ptn-ag2 is throttling my connection.
hmm 'throttling' the very same thing I'd like to do to Plusnet support.
