Can I use my old wireless router?
Hi, I have just joined plusnet's Broadband Premier service and would like to know if I can use my old DELL Truemobile 1184 Wireless broadband router with the Voyager 105 Modem?
1 REPLY
craigbrass
Hello,
As the BT Voyager is a USB modem, you cannot use it with a wireless access point. I suggest going over to http:/./www.ebuyer.com and buying a wired router which you can pick up for under £25 if you want, but I recomend DLink or Netgear for reliability. You can then just plug it right into the access point and all your wireless computers can use the net at the same time.
