Can I switch back BB PLUS now...
as i don't seem to be getting the decent speed's on PAYG that i am paying for in the evening's...so can I be put back on PLUS without being charged a regrade fee....I only switched because of te poor speed's originally experianced on PLUS!
yhanks
Fixes: 8
If you are not getting good speeds on PAYG I'd suggest that you could be seeing exchange contention and it's nothing to do with Plusnet.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
is there a way I can check for exchange contention...my last speedtest, and it's NOT acceptable..
Last Result:
Download Speed: 1310 kbps (163.8 KB/sec transfer rate)
Upload Speed: 382 kbps (47.8 KB/sec transfer rate)
Plusnet Staff
Plusnet Staff
I would discount any speed problems this evening because of this problem:
http://usertools.plus.net/status/archive/1173820552.htm
You can though check for any known exchange issues here:
http://usertools.plus.net/exchanges/
Fixes: 8
@julesp1970
Have you looked to see if you've had the ticket added to your account to say you are set up on the new network yet?
http://portal.plus.net/central/forums/viewtopic.php?p=409995#409995
Plusnet Staff
Plusnet Staff
Fixes: 159
Last Result:
While I understand that these speeds are not as high as you have previously seen they are still well above BT's acceptable levels for ADSL of 400k.
Nothing has changed on our side in regards to your account, it may have been due to the issues Dave pointed out, hopefully the speeds will be back to levels you expect.
 Chris Parr
 Plusnet Staff
just found this in closed questions...
A modify order has now completed on this account to place the customer onto the new network.
Yip, didn't you receive the email from PN about allowing you to trial the BT RIN network?
You can read discussion on the new network here
Plusnet Staff
Plusnet Staff
Fixes: 159
That means you can now test out our new network, simply update the connection details in your modem/router to use username@plusdsl2.net and you should be connected. See the following thread for more info.
https://portal.plus.net/central/forums/viewtopic.php?t=54328
 Chris Parr
 Plusnet Staff
should i find a speed diffrence? if yes, I'm not still just under 4000
Plusnet Staff
Plusnet Staff
Fixes: 159
It shouldn't affect your sync speed, 4000 is a good speed to be connected at.
The page I linked to should give you all the information about the new network and the differences it may have.
 Chris Parr
 Plusnet Staff
BUT i was on a linespeed of 4500 - 5000 and now the big drop, my line according t router is syncing at 6300
Plusnet Staff
Plusnet Staff
Fixes: 159
The drop is not due to the new network, BT have set your profile lower than previously due to a poor sync event. If your modem/router syncs higher for 3-5 days then this will be lifted up again.
 Chris Parr
 Plusnet Staff
ok , when I tried earlier to connect using the plusdsl2.net login I lost my conection completely untl about 15-20 mins ago, and speeds whee very poor last night, so let's hope it does improve.
